Documentation for Users
2.1.2
Perception Toolbox for Virtual Reality (PTVR) Manual
Go to the source code of this file.
Namespaces | |
| reticle_test_angular_size | |
Functions | |
| def | main () |
Variables | |
| int | my_reticle_diameter_deg = 2 |
| RETICLE PARAMETERS ######. More... | |
| my_contingency = ImageContingency.HEADSET | |
| string | my_eye_w_reticle = "both" |
| int | sphere_diameter_in_deg = 2 |
| Two objects having the same angular size but ... More... | |
| float | sphere_radial_distance_in_m = 1.15 |
| sphere_diameter_in_m = \ | |
| visual_angle_of_centered_object_in_deg | |
| viewing_distance_in_m | |
| float | cube_size_in_m = 0.04 |
| float | cube_radial_distance_in_m = 1.15 |
| my_world = The3DWorld () | |
